stairs not showing in plan view above insertion level
4 ANTWORTEN 4
Nachricht 1 von 5
11252 Aufrufe, 4 Antworten
I started a stair and changed it to a multilevel stair.  When I go to the floor plan above the level on which I'd inserted the stair, it does not appear.  How can I make stairs visible on the floor plans above where it's inserted?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Are the views under the same Phase?
Nachricht 3 von 5
Corsten.Au
Check in 3D if the stairs are created.. else use connect levels..
multi-storey stairs..multi-storey stairs..
Corsten
Building Designer
Nachricht 4 von 5
als Antwort auf: Corsten.Au
The stairs appear in 3D, but for some reason don't show up in plan. They exist in section, as well.
Nachricht 5 von 5
Corsten.Au
1. get rid of underlay ( this should not affect the stair views in plan.. but still try this )
2. Check " View Range" Cut plan of the view.. Cut plane should be between " 1200mm to 1500mm "
3. Check " Reveal hidden elements "
4. you may simply duplicate the view to check if it shows up in new views...
recreate stairs otherwise..
you should get this..you should get this..
Corsten
Building Designer
