Stairs not showing graphically in detail view even with the template
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
harmenGWJZ8
583 Aufrufe, 8 Antworten
Hi there,
I am creating stair plans using detail views plus a view template. The view template has all stair visibilities checked. The parent view (area plan) shows the stairs properly. Is this not possible in a detail view?
Thank you
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: harmenGWJZ8
I'm not clear what you are asking. What are we supposed to notice in those two screenshots?
Nachricht 3 von 9
hmunsell
In your 2 views, one looks like your View settings, the other looks like the View Template/VG Override settings.  Both images look the same though. What is "not showing graphically in the detail view"?
Are you referring to the stairs not being cut at the Cut Plane?
Howard Munsell
Nachricht 4 von 9
azad.Nanva
use the plan view not section and if you want the callout draw the callout in the planview, in the section view you don't have the View Range so the Revit rules not working:
but in your Detail view you use the Callout in Sectionview(I think) :
Nachricht 5 von 9
handjonathan
Hi @harmenGWJZ8
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @hmunsell @azad.Nanva helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 6 von 9
harmenGWJZ8
als Antwort auf: azad.Nanva
It is a detail view Plan View. I drew the callout box from the area plan view. It is a live view.
Nachricht 7 von 9
harmenGWJZ8
als Antwort auf: barthbradley
Oops, I forgot to show the parent view. The stairs don't show the same graphically even with the same visibility settings checked. There should be a cut line, dashed line showing the stair nosing. For some reason it does not show in the callout view from the parent area plan view.
Nachricht 8 von 9
When you create the callout, choose Floor Plan View type instead of Detail View type.
Nachricht 9 von 9
harmenGWJZ8
als Antwort auf: ToanDN
Wow, I knew it was that simple. Thank you!
