Stairs not calculating risers properly?
05:41 AM
As seen in the attached image, I have my stairs set with risers max to 7". In the image you can see the stairs are coming in at 7 1/4". The properties panel is puting out information that 'actual riser height is 7 85/256" ' Why would this ever be the case? What is the easiest way to limit risers to the actual quantity put into the 'riser max'?
