Stairs not attached to first floor
nicha713
Observer Observer
nicha713
Observer
Observer
Stairs are connected to first floor in Section view 2 but not in section view 1...am i missing something here?
Increase Far Clip offset distance. If you select the section line on plan you can see how far the section extends to graphically.
nicha713
Observer
Observer
@ToanDN . I've increased the far clip offset distance and extend the section line on plan but the stairs are still not attached. The stairs seem to be attached when I'm in modify mode but once confirm and out of modify mode its floating...
Your elevation (section) is cutting through the stairs -  not in front of it.
