stairs - length/treads or height/risers annotation
arkitek2ss
arkitek2ss
Has anyone created or figure out how to either:
combine a dimension string with a stair tag so that it reads [stair length/ # treads @ xx"]
or vise versa - create a stair tag that gives the stair length?
I've got a dimension and then a stair tag placed manually under the dimension.
just wondering
Calculated Parameter=Actual Number of Risers * Actual Tread Depth
arkitek2ss
OK, good.  now, can that be added to a dimension line OR create once the tag is applied, show a dimension lines?
actually, shouldn't it be (Actual Number of Risers * Actual Tread Depth) - Actual Tread Depth  if the stairs starts and ends with a riser.
The above screenshot is the Tag. No, you cannot put this information into a dimension automatically.
arkitek2ss
