Stairs - Israeli Standard
11 ANTWORTEN 11
Nachricht 1 von 12
alon
893 Aufrufe, 11 Antworten
I'm trying to create a set of stairs in a residential apartment building. I have been struggling how to make it so that there is essentially a "slab" underneath the stairs but by making it via the "Stair by component" way. Anyone have an ideas? Below is a section of what its supposed to look like. (Everything is in centimeters.)
11 ANTWORTEN 11
Nachricht 2 von 12
Jacob.westergaard
als Antwort auf: alon
Hi Alon,
Thank you for taking your time to post this on the forum,
I think that I most likely make use of a Model In Place stair geometry, what version of Revit are you using?
Best Regards,
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
Nachricht 3 von 12
Sahay_R
What about if you create a Stringer below the stair and play with the width and depth?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 12
als Antwort auf: Sahay_R
@Sahay_R  that was a good thinking.  He needs to use Stair by Sketch because Stair by Component doesn't allow adding stringer in the middle.
Nachricht 5 von 12
PijPiwo
als Antwort auf: ToanDN
@ToanDN, just to correct your typo, the middle stringer can be added for both types of stair :zwinkerndes_Gesicht:
Nachricht 6 von 12
als Antwort auf: PijPiwo
@PijPiwo
I have no idea how to do that for component stairs.  Can you explain?
Nachricht 7 von 12
PijPiwo
Setting aside of course, different naming that revit uses to call all of them (support, stringer, carriage).
Nachricht 8 von 12
I see.  I was looking at placing support when in the editing mode and it only allowed to pick on either side of the stair.
Thanks!
Nachricht 9 von 12
PijPiwo
There was a very similar thread a few weeks ago (see link and pic 1), but I think in this case, in-place floor sweep (picking a stringer as a 3D path) might work better joining with the floor (pic 2). Just a thought.
Nachricht 10 von 12
Sahay_R
@ToanDN I always have good thinking! @PijPiwo thank you! I am so happy to know something that @ToanDN missed!! ROFL!!!
Rina Sahay
Nachricht 11 von 12
alon
Ok, so what I have to do is make a stringer profile that I add in?
Nachricht 12 von 12
PijPiwo
If this is really the shape of your stair in plan view, I don’t think I would bother with the middle stringer thing - way too messy and you will not gonna get exactly what you’re after (middle stringers are not applied to the landings). I would just make monolithic star with increased thickness for landings and runs (to cover the framing and slab), applied treads and risers and addressed concrete detail in section view with filled region locked to the stairs so it follows the shape if the stair is changed.
