i have this problems in stairs its incomplete and just happen in Monolithic Stair why this happen and how can i fix it
... did you try to delete that stair and draw a new one to see if that keeps going on?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
.... open a new project and try to draw just the same stair
... lets see what happens?
aRcHiTeCt.JM
REVIT EXPERT ELITE
If I had to guess, I'd say it's Stair by Sketch with 1 Riser line missing. Add a Riser line to correct.
...don't you have Warnings associated with the stair?
... did you get a solution ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
Hi
possible errors / adjustments required to fix that are
1. Design issue
2. Stair path ( you may customise stair path to suite the stair, the default path doesn't work all the time )
I think your length and your distance from the first level to the second level aren't enough
you must extend your length.
I create one stair similar to you and don't have any problem.
