Stairs/ decorative panel
hi there,
I am looking for some suggestions on the direction to go with modelling a Spiral staircase.
I need staircase (spiral) with decorative panels baluster [ custom made laser cut geometric panels up the staircase]
Any of how to model this would be great - I am familiar with how to create a staircase in project and also the basics of creating families.
Thanks for any tips.
I've included a project with the staircase modelled. I hope this is what you meant.
The steps I took are as follows;
1 - Create a spiral staircase in the Revit Architectural Template
2 - Change the 1100m Railing default to the Glass panel type
3 - Open up the Panel - Glazed - 800mm
4 - Create a new profile with the desired cut
5 - Load the profile into the panel family
6 - Create a void sweep to cut that profile into the panel
7 - Constrain appropriately (Admittedly I did not which sometimes breaks the panel)
8 - Load the panel back in
9 - Remove any unnecessary parts of the railing.
