Hi
I need to change the cut line from how Revit makes it automatically to how its drawn with red line, any ideas ? : )
Kasia
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
The cut is defined by where the Cut Plane of the view is. You can influence where it occurs by using a Plan Region around the stair to raise the cut plane at just the stair.
Steve Stafford
