Stairs cut line
2 REPLIES 2
kat_koz
205 Views, 2 Replies
Stairs cut line
Hi
I need to change the cut line from how Revit makes it automatically to how its drawn with red line, any ideas ? : )
Kasia
Labels (3)
2 REPLIES 2
SteveKStafford
in reply to: kat_koz
The cut is defined by where the Cut Plane of the view is. You can influence where it occurs by using a Plan Region around the stair to raise the cut plane at just the stair.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
kat_koz
in reply to: SteveKStafford
Thank you, works perfect 🙂
Forma Design Contest
Technology Administrators
