Hi
I have created a multi-storey staircase and now I want to tag the tread numbers. There are 72 steps. I am able to tag these steps correctly in section. They go from the ground floor at step 1, up to the 4th floor at step 72. However, when I go to my plan view, the tread numbers are 55-63 and 64-72 on every level (it's a dog leg staircase with 9 steps - landing - 9 steps). How do I get the tread numbers to read correctly on each level?
I created the staircase with the base level on ground floor, the top level on 4th floor. There was no multistorey top level. Desired risers of 72. Riser height 170 and tread of 270.
Regards
Lauren
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
I'm afraid that is indeed a problem in Revit with this fuction....I'v made myself some notes on this subject in a previous post:
http://forums.autodesk.com/t5/revit-architecture/a-simple-stair-challenge/m-p/5605577#M91245 - ( post no 5)
Constantin Stroescu
Hi Constantin.
I know this is an old post.
Has this issue been resolved at all?
John
I'm afraid not...
In such a case I use a workaround:
Constantin Stroescu
You are sort of be able to do it in 2018. Not to say that 2018 multi-stairs don't come with their own (other) problems. See attached 2018 file.
it looks that in 2018 it is no need of duplicating....
Constantin Stroescu
Hey there!
Just had this problem and found out that if you select the multistory stairs and unpin each stair, you can edit individualy each "Tread/Riser Start Number" without a problem ![]()
I had the same problem and used "Tab" to cyclic select the required level of threads for numbering. Like one level below the top level, 1 Tab and so on....
