staircase direction
4 ANTWORTEN 4
Nachricht 1 von 5
amirhossein.jafarii
517 Aufrufe, 4 Antworten
staircase direction
Hello All,
I have a question.
I want to drag the arrow of the staircase I marked to the end. The architect is so obsessed  that the arrow has to go to the end of the staircases.
Thank you all for your help!
Amir
Tags (1)
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
_Vijay
als Antwort auf: amirhossein.jafarii
@amirhossein.jafarii  It will show only up to view range cut the stairs. if you need further you can use annotation like details lines or detail family.
Nachricht 3 von 5
amirhossein.jafarii
als Antwort auf: _Vijay
Thank you,
In fact, the stair I want to show to direction goes down and the cut plane should be 4' above the second floor.
now I could fix the issue by changing the family as well.
but what is shows is "straight up". what if I want to show straight down?
 like instead of showing from where we go up.
it show the direction of going down.
Thank you,
Amir
Nachricht 4 von 5
just pick your stair path > go to properties to change. thanks
Nachricht 5 von 5
No need to change the View Range for the View. Instead, draw a Plan Region around the Stairs and adjust the Plan Region View Range. TIP: Other Levels can be used in Plan Region View Range Settings.
Both these Stairs are on Level 1. Top Stair surrounded by a Plan Region and the bottom Stairs use the normal View  Range Settings.
