staircase detail
1 ANTWORT 1
Nachricht 1 von 2
219 Aufrufe, 1 Antwort
staircase detail
I am a Designer using Revit more than 3 years. Now i have some query in creating spiral staircases. I am working in Railing fabrication firm. So i need Staircase as well as Railing parts to assemble and details.. I cant make any specific spiral design with accurate dimensions. Is there any possibility to draw the customized Spiral stairs .
Hope this will help me to find the solution. I used model in place and creating some staircase structure but for hand rail and balusters are not comfortable to draw.
Thank you
1 ANTWORT 1
Nachricht 2 von 2
Kimtaurus
als Antwort auf: Anonymous
Can you give us an example of what you're trying to do (screenshot)? We don't have much to go from.
For the spiral staircase, you can always use the tool Stair by component --> Create Sketch to draw any shape you want.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
