Stair
Stair
hve-architecten
Stair
hve-architecten
Anyone have any idea to create this staircase in revit?
Most parts can be ceated with standard system families but the flowing underside i don't know how.
martijn_pater
You can do it using an Adaptive Component or In-place mass, or both probably.
martijn_pater
Not exactly ofcourse from this photograph, but here's some idea on how you could do it.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Spiral stair using massSpiral stair using mass
hve-architecten
Wow that looks a lot like the basic shape i need. Ofcourse i can add much more simple generic models to create more detail for finishing the staircase.
I tried to recreate the shape but unable to. Can you show me the steps you took to create the flowing shape?
martijn_pater
I made that one more or less as follows using wall by face on mass surface like below, which is probably the easiest to get it to look similar although actually that's not really how it's made I suppose. Maybe you have some original drawings or you can send me PM if you're looking to go more into detail with that.
Massing surfaceMassing surface
