Stair with landing at top railing continues at landing
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
FredKlopper
907 Aufrufe, 6 Antworten
simple straight stair with a landing at the top, made with landing sketch, the railing continues at the end landing.
How can I get rid of the railing at this part of the stair.
Or is there another way to end a stair with a landing.
Thanks in advance
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: FredKlopper
Place the railing using Sketch > Pick New Host > Pick the Stair > draw sketch lines on one side > Finish.
Repeat for railing on the other side.
Or,
Use Split tool to split the railing you have and delete the segment at the landing.
Nachricht 3 von 7
FredKlopper
als Antwort auf: ToanDN
I am using revit 2018, the split tool doesn't work in this version.
When I sketch the railing it doesn't follow the stair, its projected horizontal on the floor level.
Nachricht 4 von 7
Read my response again.  You need to Pick New Host when draw railing by sketch.
Nachricht 5 von 7
ennujozlagam
Nachricht 6 von 7
ennujozlagam
are you looking something like this? thanks
Nachricht 7 von 7
FredKlopper
als Antwort auf: ennujozlagam
Thank you,
It worked.
Fred
