Hi
I need to create some stairs with winder on the middle landing section. but cannot figure out a way to make it with one continuous stair. have to break into 2 stairs build the landing with floors. As a result the thread numbers are not in series.
is there any way to create them with one stair?
- That stair can certainly be created as a single component stair. Share your file.
- If it needs to stay as multiple stairs, you can set the tread number to start from any number instead of 1 for any stairs.
Why do you need to break it up into two stairs? Are you trying to mitigate for the way Revit represents stairs in Plan View? If so, there may be a better approach.
