Hi
I am using the standard arrow for my stairs, however my Up arrow head is double the size of my Dn arrow head. I tried editing it in the arrow's properties but it just changes the arrow head types but does not shrink or increase the sizes of either Dn or Up arrow heads
Thanks!
Hi! select de Up arrow and revise if it is standard like the down arrow, Could you share your stair?
Gustavo Ubriaco Contreras
The look like two different Automatic Up/Down Types. What's the Properties of each Automatic Up/Down Type?
FWIW: Arrowhead Types are defined under Additional Properties on the Manage Tab.
They are both the same arrow type.
part of my down arrow doesn't want to show up
I didn't understand the first part of your response, and here's my stair info
In these examples I have 2 stairs and both are the same type, only the stair path changes in each example
Thanks for the explanation,
Is there no way to fix a path type? or to reset it?
you could select the wrong path ___EDIT TYPE___ and change the arrow type to match with the good one. all your Stair paths will have the same arrow
Other way is Right click on the wrong stair paht___select all instances____in entire project____and change in the type selector and choose the other stair path
