stair tag custom
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
roscopeco2000
2187 Aufrufe, 7 Antworten
stair tag custom
hello guys and gals
Altered standard revit stair tag to report treads aswell as riser heights, is there a way to report stair angle aswell its not a standard parameter. Maybe i could add a sum which would multiple tread by riser to report pitch , any ideas?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: roscopeco2000
if the stair is a straight run and ends with a tread, this formula would get you there:
Calculated Parameter = atan(Run Height / (Actual Number of Treads * Actual Tread Depth))
Nachricht 3 von 8
roscopeco2000
als Antwort auf: barthbradley
i am almost there @barthbradley i had to change your formula slightly its reporting but not right any idea?  pitch 1.PNGpitch2.PNG
Nachricht 4 von 8
You would create a Calculated Parameter Label in the Stair Tag Family which uses the above formula.  Do you know how to create a Calculated Parameter?
Nachricht 5 von 8
syman2000
You can. First you click on the calculated value and then use the formula (see screenshot)
Nachricht 6 von 8
Does the Stair end with Tread?  If not, use atan(Actual Riser Height / Actual Tread Depth)
Nachricht 7 von 8
roscopeco2000
als Antwort auf: syman2000
@barthbradley @syman2000  you clever clever people well done thanks
Nachricht 8 von 8
fold1
HEY!! How did you make the run tag ?
