Message 1 of 8
I've been given a Stair Case designed by an Architect in DWG format, and I tried using it as a sketch feature of Stairs in Revit, but I can't create Risers (and hence can't complete staircase). Tread width is 250mm, In Australia Riser height can't exceed 190mm.
Floor height difference is 3300mm (between levels).
I wondering what's wrong with is DWG drawing it won't allow me to create a staircase. I've attached a DWG file of just the staircase outline.
Any help would be much apricated.
Thanks.
