Stair relation to landing
glkirk
glkirk
Good morning.
I am wondering why the top star tread is always lever with my landing.
I would like to have a riser just before the landing.
Any help?
Thanks!
azad.Nanva
did you use the Begin with Raiser and End with Raiser ?this is what you need ?
BreannaSLAXJV
Hello. When you are in the edit stair window and click on your stairs, there are 2 check boxes in the properties panel for begin/end with riser. If you select both boxes, the top should end with a riser instead of a tread. I believe you can only select the check boxes after you have started drawing the stairs.
glkirk
Yes, that seemed to be the solution. Thank you.
I did have to lower the top by one rider to achieve proper results.
azad.Nanva
I did show you too!!
