stair rail
stair rail
stair rail
Hi community! How can i connect rail like attached image! Thank you!stair.jpgstair1.jpgstair.jpg
RDAOU
Hello @Anonymous
  1. Select the Top Rail (Use the TAB key to pick only top rail)
  2. On the Properties palette click > Edit Type
  3. On the following dialog - Change Transition to Gooseneck
If this helps; kindly mark this reply Accept as Solution
is this your version Revit architecture 2015?. Because i use 2014 and i can not use Tab key to chose only Top rail, it did not work.
why in Properties , my rail is Rail Structure (Non Continuous) ,not the Continuouse Rail. So i can not find the Transition Gooseneck
RDAOU
Are you selecting the top rail only? Not the whole handrail.
When you tab over it the top rail should turn light blue without the balusters and intermediate rails
Sent from my iPhone
My proble is 3 rail is 3 separated part because i draw one by one rail then i apply Pick new host to stair so now i can not chose the whole Rail and use  Transition Gooseneck? What can i do?
