Hallo, can someone provide a solution about a problem with the stair? because I used a stair path that my teacher gave to me but I don't know how to make the line till the end of all risers, and not how I show you.
Thank you for the help.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
The problem is that my teacher wants the section's height at 1.20 meters and the stair line under the 1.20 and also after, that arrives at the end of the stair, but I don't know how to do this
Did he teach you about Plan Region? Use it to change the view range just for the stair.
