HI,
I'm missing stair numbers when printing,
When zooming in & out in Revit the stair numbers disappear and reappear sporadically?
See attached.
Gelöst! Gehe zur Lösung
Gelöst von PrathapSekar. Gehe zur Lösung
Have you tried the following link?
Guess this may help you, if you did not try the above link already!
Hi Thanks for the link;
The zooming in/out and missing stair numbers is a problem. But I know the tread numbering is in the model.
But It's more that the numbers are not printing
- to fix this I had to number each missing step (with text) individually which was quite tedious, and annoying due to knowing the stairs were already numbered.
thanks again I reviewed the link;
If I close the file, switch off Accelerated Hardware - open file & print, the stair numbers appear in the print!
I don't fully understand how the the Accelerated Hardware is involved with producing a PDF, but it appears to work.
But like I said; it only works after closing file, changing settings, and reopening again to take effect.
