Stair number doesn't show up
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
839 Aufrufe, 8 Antworten
Hi Friends. I can't change the step numbers. I have attached the file for your review. Thank you for help.
8 ANTWORTEN 8
Nachricht 2 von 9
MostafaElashmawy
als Antwort auf: Anonymous
after modelling a stair, the steps number will work only as a way to control the the height of the riser.
to change the actual steps number, after editing the step number, click on edit stair and drag the end of the stair to add more steps.
Mostafa Elashmawy
Nachricht 3 von 9
als Antwort auf: MostafaElashmawy
No, I just need to change the annotation of UP to 6 UP.
Nachricht 4 von 9
RDAOU
BUMP
...it does change if you hit Enter instead of Apply!
Nachricht 5 von 9
Nachricht 6 von 9
RDAOU
als Antwort auf: ToanDN
why does it work on yours and not mine!!
Works when I hit Enter instead of apply
Nachricht 7 von 9
als Antwort auf: RDAOU
It should. Just type in the text box next to Up text.
Nachricht 8 von 9
Toan, It doesn't work for me.
Nachricht 9 von 9
Here's your file.  Use Enter, not Apply button after typing in 6 Up.  See @RDAOU post above.
