Announcements
Stair nosing not visible on sides in plan
Hi All,
I'm having an issue where a stair I've created uses a nosing profile that is applied to both the right and left sides of the stair as well as the front. The geometry is present in 3d, but does not appear in plan.
In the images attached, the red arrows are the nosing (that should in plan be) extending around the steps. The blue arrows are part of the model in place family for the stair details because Revit will not return the nosing to the stringer. Lastly, the green arrow is the heel of the nosing on the tread below, so not really that relevant. The main issue here is that the nosing should be visible on the side of the tread in plan and it isn't.
I've tried all of the VG settings and view range settings. No luck. Has anyone else had this issue?
Michael
Thoughts?
Redrunner92
Now that you bring this up, I'm baffled as well. I haven't customized a stair so much until I tried just now. I played with all the settings in the Run Type for each of the stair types: assembled, cast-in-place and precast. None of these settings made the nosing profile visible in plan view, even when I used an obnoxious 3" x 6" nosing profile extending above the treads. However, as you may have found, the Run Type is able to be selected in plan view, it merely doesn't have permanent lines in plan view, so to speak. See the images below (the instances are identical, I simply copied one stair over).
Plan view with Run Type selectedPlan view with Run Type selected
3D view3D view
As for your first question, yes I am having this issue as well. As for your second, I'm thinking the system family for stairs has some symbolic lines and/or masking regions applied to its plan view which we, the end users, cannot change. Unfortunately I have no solution besides drawing filled regions and constraining them to your stairs (which I readily admit is the worst way to do this if other solutions are present).
I will be eager to hear if you find a viable solution or workaround.
Thank you both for your feedback and comment. And an especially big "thank" you to Autodesk...
Alex_Pendray
Why is this flagged as a solution? This issue is not solved as you mentioned. It is unsolvable as it stands now.  This is a genuine question.
yonatangrin121
Observer
Observer
AND NOW?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
