Hi, to avoid the strange triangular gap I've encountered in the past between the top of stair and landing (underside) I've discovered that by adding a small landing (approx a foot) this creates a clean joint between the stair and landing.
However on plan and section the landing brings with it some additional lines (See attached images) I know that I can use the linework tool. However most of our projects are 30+ levels....
Attempts:
Is there a way to automatically hide these landing lines ?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Edit: sorry responded to wrong post
Like this?
Yes, this method without the added landing on top works, however you are still left with the triangular gap underneath which Is the reason for the 1 FT landing on top. We don't model stair landings and use floors.
By adding a landing to the top of the stairs It joins the landing better, and looks like this:
But the only issue is the visible landing line work.
It is not what I have done...no linework involved in the entire process.
See attached 2022 Model attached if you want to see how it works
