I have read some previous posts on this issue but as yet have been unable to resolve it.
I have a continuous guard that is hosted to stairs between ground and second floor. I have selected in the type properties to apply a landing height adjustment, to conform to local building code requirements. I've modfied the baluster base offset in this stair type up 4", to meet a flat steel bottom plate (see image). However, as I read happening to others, the landing height adjustment is being applied to the bottom plate and balusters, not just to the top of the guard as I would expect. Does anyone know of a value in the type parameters that will correct this, or do I need to duplicate the guard types and have a dedicated type just for the landing? It seems a bit pointless having the landing height adjustment if this is the case!
Honestly, I think a second railing would be the best approach. Seems like you could fit one in there nicely too.
It looks like your bottom rail elevation is constrained to the top rail, not the host.
