Stair Family
4 ANTWORTEN 4
Nachricht 1 von 5
chrysaJT3MN
343 Aufrufe, 4 Antworten
Stair Family
Hi All,
I need some help with these stairs. They're custom, and when I draw them in Revit it creates a little step at the underside as shown in the photo. As a result I can not use the underside of the stairs as a path for railings or the wall below the stairs. I've tried to split the stair into 3 different ones but doesn't work. Any idea on how to draw it?
Many Thanks,
C
Tags (2)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: chrysaJT3MN
Post the RVT.
Nachricht 3 von 5
chrysaJT3MN
als Antwort auf: barthbradley
See below
Nachricht 4 von 5
Are you referring to the underside of the stairs?  You want it to be smooth as a baby's butt, don't you?  You can't get there with any setting in the Stair Type, if that's what you want to confirm.
Nachricht 5 von 5
chrysaJT3MN
yes this is what I want. This small steps on the underside prevents me from creating the hand railing as the path for the sweep is not continuous. Very annoying. Any suggestion to make it work?
