Stair Edit Problem
1 ANTWORT 1
Nachricht 1 von 2
wayne_fulp
957 Aufrufe, 1 Antwort
Stair Edit Problem
I am working with stairs in Revit 2018 and have a strange issue. I can create assembled stairs and stairs by sketch with no problem. I wish to go back and modify the stairs and this should be a simple issue. I choose the stairs, they turn blue to show they are chosen, and then click Edit Stairs. The Edit Stairs menu appears for about 1 second and I can physically see the edit sketch button but then the menu changes to the Modify/Create Stair menu and my chosen staircase is no longer highlighted. I can create a new staircase but cannot edit any single one once placed. This is consistent throughout several drawings and it happens 100 percent of the time. I am at a loss as the stair function is useless to me if I can't edit stairs after they are created. Any and all help would be appreciated.
1 ANTWORT 1
Nachricht 2 von 2
ennujozlagam
als Antwort auf: wayne_fulp
hello, install latest updates 2018.2 and see id helps. thanks
