Im trying to create stairs with a middle stringer and keep getting a message that the middle stringer cant be created.
Please advise.
Attached is the screenshot of the stringer properties.
Thank you
Can you upload the Revit file to a Cloud and share the link?
Also, I see you created the stair by sketch - have you tried Stair by Components?
I doesnt seem to allow me to upload the revit file. I tried cleaning it up but it still doesnt allow.
I did try stair by component as well.
@Anonymous wrote:Similar idea but I attached what it looks like
Odd warning. Are you sure the Stair: Support subcategory is turned on under Visibility and Graphics?
@Anonymous wrote:
Yes I have dropbox
Excellent! Now upload your Revit file to your Dropbox and share the link.
I'm stumped, but I found a workaround. Get rid of the middle stringer and add either a left or right one and offset it.
Hi, I have actually the same problem, your creative idea of using a offset, is amazing and thank you for it, but in my case it doesn't work because im trying to make a stair with a sketch, and if i'm using the offset it is following the sketch,
i attached here a screenshot of my resolt,
I will appreciate if someone can help me.
