stair calculator
3 ANTWORTEN 3
Nachricht 1 von 4
354 Aufrufe, 3 Antworten
stair calculator
Hi. I am trying to use the stair calculator to modify the stair slope. While use stair calculator is checked, I change the numbers and nothing happens and I get the same thing as before. No slope change. Am I missing something?
3 ANTWORTEN 3
Nachricht 2 von 4
constantin.stroescu
als Antwort auf: Anonymous
well , this Calculation Rule has to be set before starting a new stair and is not used to modify an existing one.
It is a predefined rule:
https://www.archdaily.com/892647/how-to-make-calculations-for-staircase-designs
as can be seen from the message included in the dialog window:
Constantin Stroescu
Nachricht 3 von 4
als Antwort auf: constantin.stroescu
Hi. Yes that’s what I do. I don’t try to modify existing stairs. I just don’t see the difference between using the stair calculator and not using it.
Nachricht 4 von 4
constantin.stroescu
have at this video that explains why and how to use Stair Calculator:
https://www.youtube.com/watch?v=AocUQxm2BG8#action=share
Constantin Stroescu
