Stair Break line not moving after view range change
advandes
Advisor Advisor
advandes
For some reason in this particular view I can not get the stair break lines to move up even after changing the view range in the main view and with a Plan region. See attached screen captures. Help is very much appreciated. Thanks, Aaron
AAG
Advance Design
Alfredo_Medina
Revit has trouble handling the view range of a stair when the plan region has an irregular shape. You need to handle this in a different way. If possible, use a rectangular plan region, or use the same view range of the view plus other means such as linework.
advandes
That is unfortunate, but it did work. Thanks!
AAG
Advance Design
j0258169
I am having this error with a rectangular plan region. Revit 2017. Is this still an issue?
Does the plan region cover the stair entirely, including all runs and landings?
