Stair Arrow Path
2 ANTWORTEN 2
Nachricht 1 von 3
dsalvagni
112 Aufrufe, 2 Antworten
Stair Arrow Path
Is there a way to get the stair arrow path to change when you are on a certain floor.  I have a single run stair that goes from the sub basement to the basement and it slopes up when i am in the sub basement floor plan, when i am in the basement floor plan the stair shows the arrow as going up, but i want the arrow to show going down on the basement plan.  is that possible?
2 ANTWORTEN 2
Nachricht 2 von 3
RC_RVT
als Antwort auf: dsalvagni
You should be able to have one Stair Path for "UP" and then one stair path for "DOWN". If you tab over the arrow and select the path, you can change the type and therefore can change the direction of the arrow. This can also be varied per level as you are wanting, with one level showing down and the other showing up.
If this works, please mark it as an accepted solution. This helps make the forum a better place.
Nachricht 3 von 3
RDAOU
@dsalvagni
As a matter of fact, the available types are "Fixed UP" or "Automatic UP/Down Direction"...If you use the second one it should swap automatically. When on the upper floor it shows down and when on the lower it shows up
