Stacked Walls
Stacked Walls
glkirk
Stacked Walls
glkirk
I just started using "Stacked Walls" for the ease of lining up foundations under wall.
The only thing I don't understand is how to manipulate them to show the siding go down past the first floor to the foundation level, like in real life.
I hate to think that I would have to use "Levels" to do this.
Can anyone help me understand how to change where the split happens so I can show how elevations look in real life?
The attached pic only shows the very beginning of detailing.
Thanks!
You mean like this:
glkirk
No, That doesn't seem to be able to do anything.
And when I try to edit type, nothing seems to be editable (Grayed out)
Your bottom screenshot shows the two wall types that are stacked. If you want to edit one of their properties, you need to right-click on the wall type in the Project Browser and select "Edit Type".  Or, you can just TAB-Select the individual wall.
