Hi guys,
I changed the walls from basic to stacked and all joins have gone crazy after that, and though I fixed every join and cleaned them up, it defects again; like if I fix a wall join at some end, the other end defects? By the way, I have the same heights of the stacked walls, the layers are different. Is there any solution? Please see attached screen shot.
Thank you.
What you describe is exactly what I would expect to happen if I changed Basic Walls to Stacked Walls.
@maYHS8K wrote:
What's the issue with that?
Because there's a lot going on there. You're introducing two walls instead of one to the join condition. I would naturally expect it be problematic with certain join conditions. Revit is good, but not that good.
