Dear all,
I have a stacked wall with different finish material (both interior and exterior) assigned to bottom and top wall.
The problem is Revit sometimes displays the division line, sometimes it doesnt. Did anyone have the same issue?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
... you need to check the visibility settings in each view.
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
By definition, they are STACKED walls. Why wouldn't you expect to see the "division"? Maybe I'm misunderstanding.
