square footage table
georgeZV3BT
georgeZV3BT
Is there a way to make a square footage table that has the following
Living
porches
brick ledge
garage
Ric_Weber
@georgeZV3BT
  1. In Revit, they are not called tables, they are schedules.
  2. I am really not sure what you're saying there.  You want a schedule to show total square footages of rooms by category?  So total area of all of the Living Rooms, Porches, and Garages?  Yes there is a way to do that.  But you also have in your list, "brick ledge", so that throws me. If you could reword this question to better explain your question that would help a lot.
Ric Weber
If this post helps you, please like it or mark it as your solution. Thank you.
My Ideas: https://forums.autodesk.com/t5/forums/recentpostspage/post-type/thread/interaction-style/idea/user-id/12292525
georgeZV3BT
thank you for your input.
