Square footage isnt showing up
Hey guys,
I'm measuring square footage and it was working earlier, and now I try to use the same command and the square footage isn't showing up.
any idea on how to fix it? I'll post some screenshots.
So the top photo isn't showing the square footage, like the one below it
Much appreciated!
ChrisNeedhamNZ
It looks like you just need to place an area tag.
Chris Needham
Whangarei
New Zealand
ennujozlagam
@Anonymous hello, go to architecture > room > tag on placement > properties and check properties type if those 3 are tick. thanks
FGPerraudin
Agreed, place an area tag.
(the button is located next to the area button)
Be careful, on the picture you posted, you have two areas in the same enclosure...
It might not quantify one of them!
Francois-Gabriel Perraudin
BIM management and coaching
You can add an Area Tag as suggested.
In the future, if you want a Tag to appear automatically when you create an Area, make sure the Tag on placement button is activated.
