Hello everyone I would like to ask if there is a way to show wall base and top constraint on plans? I need it on my foundation plans, where I would like to show the bottom of the foundation and the top of the foundation. Today, I only write it in a text box, but it would be more optimal if it referred to a parameter so if there were changes this would appear automatically. Anyone who can help?
Unfortunately that is not possible in native Revit. However, you can create a tag that shows you the base offset and unconnected height.
-Create generic tag
-Change it's category to wall tag
-Place label with the parameters you want
If you really want to schedule the level and so on, you need to create a shared parameter and duplicate some parameters. Wouldn't recommend it.
Hi
There is a way to show top and bottom spot elevation for Floor.. so may be instead of wall you can create
that part using floor..
do you think this will help you..
Spot Elevation tag
