Spot Slope unit format question
5 ANTWORTEN 5
Nachricht 1 von 6
james
506 Aufrufe, 5 Antworten
I need my spot slopes to show "1H" over "xV" with each number on each side of the triangle.  Can't see a way to add separate suffixes to the horizontal and vertical values.
I'd even settle for a simple 1 over x, but don't see any way to do that either.  I can get 10 or 12 over x with the Ratio :10 or 12 unit style.  Not sure why the Ratio :1 style doesn't follow the same format and just reports a lonely single "1" by itself.
So annoying and stupid Autodesk makes it so hard to format basic things like this.  Principals are getting really tired of it.
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: james
Not sure if you ever switch the arrow to triangle?
Here you can set whatever unit you want to display
Nachricht 3 von 6
james
Did you see my attachment with the slope triangle?  None of the unit formats reports a 1 on the vertical leg and a 1 on the horizontal.
Nachricht 4 von 6
Does x:10 or x:100 work?
Nachricht 5 von 6
james
als Antwort auf: ToanDN
No, the architectural standard is to show a ratio of vertical to horizontal.  "1H:1V" for 12:12 or "1.3:1V" for 16:12, for example.
How can I tell revit to simply put a "1" on the vertical leg and report a decimal on the bottom?
Nachricht 6 von 6
jay_colcombe
I do not feel this is achievable in Revit directly as trying to use Alternate Units as a workaround to force another Ratio Value in will not work either.
I would suggest in this instance you would need to create your own Tag/Symbol using an Annotation Symbol and add some Text in there and possibly even Parameter driven if necessary to replicate the image as initially shown.
Jay Colcombe
Autodesk Certified Instructor
