SPOT SLOPE NOT READING GREATER THAN 12
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
jledgewood409
1940 Aufrufe, 14 Antworten
i have roof pitches that are 16"/12". when i place a spot slope on said roof it reads the 16" as something else. i am including a screen shot that shows the spot slope and the dimensions that read the correct slope.
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: jledgewood409
Change reported units for slope? Project Unit=>Slope, or under the Type Parameters for the Family.
...sounds like want a ratio:12 , not rise:run
Nachricht 3 von 15
Works here.  What are the Spot slope type settings?
Nachricht 4 von 15
jledgewood409
als Antwort auf: ToanDN
the slope ratio that you have hi-lighted matches mine. I am not sure what in the type settings that you are asking me about?
Nachricht 5 von 15
Select the Spot Slope and Edit Type.
Nachricht 6 von 15
jledgewood409
als Antwort auf: barthbradley
I am attaching a screen shot of the spot slope type properties
Nachricht 7 von 15
Still can't replicate it.  You may need to share a revit file.
Nachricht 8 von 15
is that a 22 1/2" : 12" Roof Slope, @ToanDN?  A 16":12" Roof Slope is 11 3/4"or 75% of 12".
Nachricht 9 von 15
No it is a 16"-per-foot sloped roof.
Nachricht 10 von 15
Nachricht 11 von 15
Left is 16"-per-foot, right is 9"-per-foot.  What are you trying to say?
Nachricht 12 von 15
Nachricht 13 von 15
Any guesses @ToanDN? Voodoo Magic? Not quite...
...yes, the spot annotation is real; not faked
Nachricht 14 von 15
I know - placed on surfaces versus placed on the edge between 2 sloped surfaces.
@jledgewood409  you got it, bud?  what you see is a spot elevation reporting the intersection of 2 sloped planes of a roof.
Nachricht 15 von 15
@jledgewood409: Use the tab key to select the right surface when placing your slope annotation. Currently it's referencing the hip slope.
