I have a question to annotating by Spot Slope . Is it possible to make it works using a Structural Plan with View Direction set as "UP"? In my case, drawings are made with this setup, so I can see only "flat" surface, but I have to describe "sloped" one.
I thought about some workaround, e.g. using model line on workplane set on sloped surface. It's possible to use Spot Slope on model line, but it's not very effective.
Do You have any ideas?
Regards
Piotr
Okay, so paint doesn't work. But a thin veneer on the sloped side does.
That's the best I can come UP with. ![]()
BTW: if you've got a bunch of 'em, Select All Instances, Copy/Paste Aligned to Same Place, and toggle the Type of all the copies all in one fell swoop.
@barthbradley Your solution works for generic models. I have floor family, because it's required to Robot Structural Analysis ![]()
Using a model line drawn on the slope to host the spot slope would be my workaround.
