Could you tell me how is possible to change the elevation of the Survey point and the Spot Elevation that I have (which corresponds to Survey point too) to don't change its value?
Do I miss something?
Thank you in advance!
Change the Elevation of the Survey Point and Spot Elevation simultaneously?
Move both at the same time.
Hi
Must Change Type Elevation this Edite Type Spot Elevation.
If it solves your problem, feel free to click Accept Solution.
