Spot Elevation Rotation
danny_yang
danny_yang
Hi Guys,
I am using spot elevations in a plan. I have rotated the view 90 degrees so that means that all my spot elevations are vertical. There is a type parameter that can change the orientation but if i do that all my spot elevations in other views will be rotated and i dont want that. So, how can i make that type parameter an instance parameter? I can seem to find the setting?!
wrong orientationwrong orientationhow can i make this an instance parameter? what are the steps?how can i make this an instance parameter? what are the steps?
constantin.stroescu
Duplicate to create a new type and change the label orientation.
Or don't rotate views on sheet, create scope boxes, assigned to the views you want to rotate, then rotate the scope boxes.
danny_yang
thanks for the video, for some reason our spot elevations dont work that way, i will try to figure out why. But what you showed is how i would expect it to work.
danny_yang
Sooooooooooooooooooo, after a second look i understand the difference ! You are actually rotating the crop view and not the sheet itself. This keeps the level readable! Thank you man for you video !! Owe you a virtual beer haha!
