Spot elevation - gap between element and leader
3 ANTWORTEN 3
Nachricht 1 von 4
Xapod
1596 Aufrufe, 3 Antworten
Hello
I want to create an spot elevation where there is a gap between the element and the leader. I can't find a proper way to do this.
this is what I would want:
Right now I'm doing this by setting the leader to white and adding a dashed line in my symbol family. However this isn't the best way because the white leaders overwrites the dashed line.
Anyone has a way to solve this?
Kind regards
3 ANTWORTEN 3
Nachricht 2 von 4
Mirko.Jurcevic
als Antwort auf: Xapod
I think you are on the good way, just nudge your dashed line in family up a bit (click on the line and press arrow key on the keyboard)
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Nachricht 3 von 4
Corsten.Au
als Antwort auf: Mirko.Jurcevic
Nachricht 4 von 4
Mark.Ackerley
Hey,
Apologies for commenting on an old post, but perhaps this helps others...
If you turn on the reference planes in the family you can see that you can shunt the symbol off to the right and extent the line, so it isn't covered by the leader.
Obviously you then need to adjust the elevation text alignment.
Warning:  When loading the adjusted family into a view with placed instances Revit shut the window.  The placed instances had to be replaced.
Hope that's of interest,
Mark
