Spot Coordinates value not visible
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
wjkim
1192 Aufrufe, 6 Antworten
Spot coordination values are not visible in the project.
Spot elevation is fine.
I copied that object into a new project and applied it, and it works fine there.
Does anyone know which setting is the problem?
Beschriftungen (1)
6 ANTWORTEN 6
Nachricht 2 von 7
joe_keogh
als Antwort auf: wjkim
Hi @wjkim
Can you attach the file to your reply so that we can have a look at it?
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 3 von 7
ennujozlagam
need to pick your spot coordinates and edit type and change setting, see sample attached. thanks
Nachricht 4 von 7
wjkim
als Antwort auf: joe_keogh
attach part of the file in question.
Nachricht 5 von 7
_Vijay
open new Revit standard template. copy the coordination famil and paste it will show.
Nachricht 6 von 7
hmunsell
your Top and Bottom values are set to None.  i beleve that is what @ennujozlagam was trying to show you.
Howard Munsell
Nachricht 7 von 7
wjkim
als Antwort auf: hmunsell
I didn't recognize that. Thank you.
