Hi, I have inset some wall sweeps in my wall section profile to show timber frame plates in my sections. Which works fine, until I have to split a wall into parts- eg currently I'm splitting a brick veneer wall into parts so filters can apply the correct line styles to them automatically. when I split the brick veneer wall into parts, the detail I have hosted in my wall plate sweeps, disappears. Any thoughts?
P.S. the sill cut detail is controlled by a visibility parameter in the window family, not the wall, so it works fine.
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Yes it disappears because the detail item resides in the Original component not in the part. If you need the detail item visible, you need to
I meant the sweep (including the detail component) needs to be a separate component/family
ie: something as follows
I found that if you don't have the sweep cut into the wall and just sit on the face, it does not conflict with the split wall.
