Splitface asociated to Parameters
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
spizarroXRVKR
469 Aufrufe, 9 Antworten
Hi, Im modeling a Hospital. I need to paint over 2.000 rooms with four walls each (approximately). My problem is that I need to paint under the ceiling, but If i SplitFace every wall and adjust the heigh of the split by hand it will take for ever. So, is there a way to asociate the splitfae to a scopebox or any parameter that allows me to controll it all over the project? (sory if my english is bad)
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: spizarroXRVKR
Are the rooms same height?
Nachricht 3 von 10
spizarroXRVKR
als Antwort auf: ToanDN
Most of them are. We have a height for the hallways and another for the rest of them, with some exceptions.
Nachricht 4 von 10
You can create wall types and split region in the type properties for the common heights then you only need to use manually split face and paint a few odd ones.
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revi...
Or use stacked walls.
Nachricht 5 von 10
spizarroXRVKR
Thanks! thats actually pretty helpful
Nachricht 6 von 10
Why? Are you actually "showing" all 2000 rooms in your documentation?  Or are you doing this for Material Takeoff Scheduling?
Nachricht 7 von 10
spizarroXRVKR
als Antwort auf: barthbradley
As you said, its about schedules and quantification, not about the room itself.
Nachricht 8 von 10
Well, all I know is that modifying 2000 Rooms - and God know how many Walls - is an extraordinary undertaking.  There might be a faster and easier way to include the needed information in the MTO without needing to actually model every single instance.  Fundamentally, you are only applying Paint (having only 2D properties) to Split Faces.  So, if the length and width of the Split Faces are the same for all 2000 rooms, then 2000 x (length x width) would be the total of the Painted Areas.  Catch my drift?
....Whoa! I just noticed you said 2000 Room with 4 walls each!  8000 modifications in total!  C'mon! You seriously intend to make 8000 Split Faces?
Nachricht 9 von 10
spizarroXRVKR
Thanks for the advice, I totally agree with you. Saddly my BIM Manager is the one obsessed with the idea of modelling every single element on the building and he makes the final call. I would rather make a math formula to calculate it.
Nachricht 10 von 10
Dang! It would have been so much easier if you modeled the Rooms in Groups - assuming there are only a few different configurations used throughout the entire model. Obviously, you would have 2000 Groups.
