Split with Gap in Elevation Level
Is there any option to create a split with gap in Elevation Level as section. We have attached a snap for your reference.
Thanks in advance!
constantin.stroescu
Use a Croped View and click on the border's small icon : Vertical View Break...
https://chronicle.autodesk.com/main/details/78e81d20-b718-4e8a-8853-e64b30c404c7
Constantin Stroescu
Thanks for your reply. Mainly we want to hide Elevation Level line, the portion where we break crop region.
constantin.stroescu
In such a case , I use Scope Box  and arange on sheet:
  1. In a Floor Plan View > View >Create > Scope Box - make rectangles to delimitate the areas you wnat to isolate
  2. from Properties - name them as you want so to manage them easily
  3. make two duplicates of the Elevation View and from Properties> Extents >choose Scope Box 1 for the first duplicate and Scope Box 2 for the second duplicated view . Work the Views to look as you want to
  4. In a new Sheet , insert  the two Views (with Scope Box 1 and Scope Box 2)
  5. Scope Box can be visualized  in Floor Plan Views and in 3d Views
Constantin Stroescu
Thanks a lot for your clarification.
So for now we can't do this with a single view. If we need then go with scope box option with placing 2 views with manual adjustment in a sheet.
If this features will be incorporated in next release then it may be helpful to all of us Smiley Happy
