Split Toposolid consistently fails on any shapes with mild complexity...
10 ANTWORTEN 10
Nachricht 1 von 11
PowellDesign
586 Aufrufe, 10 Antworten
Hi all,
When working with a toposolid created from an actual survey - trying to divide it up into workable site geometry ... I'm getting this message over and over again:
Seeing this consistently...Seeing this consistently...
An export of the error log returns an identical message with no further info.
I've attached a copy of the topo with the proposed split line as a detail line to pick.
If anyone (Autodesk or otherwise) could help that would be great.
Beschriftungen (2)
10 ANTWORTEN 10
Nachricht 2 von 11
Alfredo_Medina
als Antwort auf: PowellDesign
If the split tool fails, and you must separate the terrain in parts, consider copy-pasting the toposolid at the same place, and then editing the boundaries of both parts.
Nachricht 3 von 11
PowellDesign
als Antwort auf: Alfredo_Medina
Hi @Alfredo_Medina ... I had tried the method you suggest - but all the boundary points revert to an elevation of zero (which defeats the purpose). Thanks for the suggestion though.
It would be good to understand what conditions lead to a fail. I've had some success now offsetting the lines from the breakline / folding lines (by a small increment like 10mm) so I think it might be involved with that somehow? This is the best workaround I've found so far but its less than ideal! Creates 3 times the number of points along that edge.
Interested to hear what other workarounds people have found.
Nachricht 4 von 11
No issues splitting here.
Nachricht 5 von 11
Use a Spline Line
Nachricht 6 von 11
Use spline instead of too many line segments.
Nachricht 7 von 11
PowellDesign
Thanks folks good suggestions. @ToanDN I don't think it has a relationship to the number of line segments (as offsetting the same number of line segments by 10mm is still successful) ... The spline solution isn't really practical - these split lines are being picked from a survey file and I really need to remain accurate to this.
Nachricht 8 von 11
Why do you need to split it in two?
You could cut it with a mass.
Nachricht 9 von 11
That is splitting hair.
1. You can draw a spline with control points matching the lines endpoints.
2. Based on the nature of that split, I believe the intent was a smooth curve and they extrapolated it to line segments.  Drawings are to deliver the design intent and the spline serves that purpose.
3. It is a sitework, not an iPhone mock-up template, so consider the reasonable tolerance required, it isn't in the realm of millimeters.
Nachricht 10 von 11
PowellDesign
Thanks for the effort in coming up with a spline workaround. It is a good solution however considering the number of split lines I need to reproduce a 10mm offset is going to work better in this context (both in terms of accuracy and time).
Nachricht 11 von 11
Use TAB key to select multiple contiguous lines in one fell swoop.
